I RECENTLY PURCHASED A 1974 L THRU P.I. AND IN PREFORMING SOME UPGRADES AND GENERAL CLEAN UP I HAVE NOTICED THAT THE HOT WIRE TO THE ELETRIC CHOCK COIL WAS HOOKED TO HT BATT + SIDE OF THE COIL, I HAVE RAN A DIRECT FEED TO HE CHOCKE FROM THE FUSE PANE, HOWEVER I HAVE FOUND THAT I ONLY HAVE 3.9 VOLTS AT THE COIL. THE CURRENT IGNITION IS A FORD DURA SPARK II, IS THIS NORMAL? THANKS FOR ANY ANSWERS.
