I needed to adjust the linkage and am looking at the entire system.
I installed one of those billet aluminum trunions with the teflon bushing in it.
It could be slicker but since I needed to disassemble the universal joint from the ZF input shaft, I noticed how stiff the universal joint bearings are.
They are stiff.
They don't appear to be disassemblable and they have metal plugs over them like the ball joints do.
I was wondering if anyone had put zerk fittings in thiers or if it is even doable.
Otherwise it's going to be a needle fitting on the grease gun to get into them, and that ain't going to be easy.
