Mark,
Make sure you give the motor a manual spin before your call the oil pan finished. Depending if you have a stroker engine, there could be a clearence issue with the crank scraper on the pan.
I had this issue with my 427 stroker windsor. A little work with a nibbler and file on the crank scraper fixed the problem. Saves headaches later in your project.
