Mechanical Aptitude test
http://www.forddoctorsdts.com/quizzes/MechanicalAptitude.php
quote:It states that in a normally aspirated engine what causes the air fuel mixture to enter the cylinder?? The answer was atmospheric pressure causes it to enter the cylinder,???? I always thought the suction caused by the pistons downstroke created a vacum to fill the cylinder????
quote:Originally posted by MARLIN JACK:
...You Guys must have been asleep in physics class!! There IS NO SUCH THING AS 'VACUUM'!!!! You can't say Here in this jar I have a Vacuum! Because there is nothing there! Zero! And when You try to 'plug' that into an equation; You come up with Zero! There IS an 'Absence of Atmospheric Pressure'! When the Piston moves down IT creates a SPACE that the Atmospheric Pressure rushes in to FILL...
quote:What questions? I'm sure you'd get plenty of input here to provide an explanation.
quote:How do you tell which one(s) you missed?
To 'Boil' a jar of water at room temp, put the jar in a 'Bell Jar' and remove the 'Atmospheric Pressure'. The water will 'Look' as if it were Boiling but it is not boiling from being heated-up; it is merely the RELEASE of the air molecules that were compressed into the H2O under the PRESSURE of Our ATMOSPHERE. Those who Do Not Know, Think that the water is Boiling...quote:Originally posted by JeffS:
Just curious Marlin, so whats the trick to making a jar of water boil at room temp??
Jeff
Yes!! The Hissing You hear as a Leak is Atmospheric Pressure rushing 'IN' to fill the SPACE that has been created when the Pistons Move Down in Their Bores! See! Your 'Getting IT'!!...quote:Originally posted by ParaPantera:quote:Originally posted by MARLIN JACK:
So the next time I try to find a "Vacuum" leak in a "vacuum" line, I should first check the component labeled "Absence of atmospheric pressure" line?
Doug! You Have it Right-On!! And the Hg is PUSHED up that tube 29 to 31 Inches, Because the Atmospheric Pressure is Pushing DOWN on the RESERVOIR of Murcury! Thank-You...quote:Originally posted by PanteraDoug:
Yes. Check for negative (-) atmospheric pressure measured in inches of mercury.
A Jar minus Atmospheric Pressure is a Jar Full of Nothing!! ...
quote:Actually, this is not totally accurate. If you lower the pressure enough, the water will actually boil as in change states from a liquid to gas. Here are a few boiling points for water in a vacuum:
212F - 0Hg
72F - 29.12Hg
-70F - 29.9195Hg
So H20 gas will form at -70 degrees F if you lower the pressure enough.
