I may get this backwards as of this moment but I believe that you add the intake closing point in degrees and the exhaust opening in degrees.
The overlap data I know is the theoretical and therfore the advertised.
Two points here 1)you can only reduce the amount of blowback by reducing the overlap, not eliminate it. I don't think anyone knows the safe number to run. I don't. The special "weber cams" I have seen have 25 to 35 degrees overlap. That is about what a factory cam has in Grandma's stationwagon.
The modern day term for copying what works as a guideline is modelling.
The GT40s and Comp Cobras didn't worry much about this and thus ran steady fuel plumes in competion. They ran open stacks so it reduces the risk of fire to your car and can be like spraying insectacide in the face of the guy on your bumper, so they ran a lot of overlap anyhow.
The GT40s had a plexiglass window over them so the I guess the fire was contained in the car not thrown on the competetors?
2) even if you go to IR FI, I don't know if in actuality you eliminiate the blowback. It is assumed that the fuel plume from the IDA's is because it is a carb with fuel in constant suspension and that the timing of the FI is perfect and the engine takes all of the fuel suspension in the intake port into the chamber.
Like I said, assumed.
I think the reality is that you will still have a percentage of blow back. How much? Beats me. That's why you have to test.
Engine chassis dynos are more common these days. Seems like everyone has one in the basement (I don't).
Looking at Quellas IR FI setups, they all run air cleaners, at least on the street. There aren't a lot of people that I would listen to about this subject. Dennis is.
Most don't even know WTF one is talking about but the fuel blowback isn't anything to mess around with. It soaks the air cleaner elements with fuel and it's only a matter of time before, gaboom.
This situation is absolutely the undeniable part of Webers being a "race" setup. Pay your money and take your chaces.
I saw a few of Inglese' set up catch fire under open track conditions.
Ask Quella for a cam to run with the Webers. It's your best bet.
Oh, somewhere in some Weber publication, each throat of a 48 IDA was stated to be 350 cfm. I presume that varies with the size of the auxiliary ventury which is changeable. If so I don't know if the 350 is for a 45mm or a 37mm, etc.
That nice chart that Holley did so you could pick the cfm of your carb doesn't apply to IR manifolds. Forget about it altogether.
The "desk top dyno's" tend to agree with this flow numbers as being required on an IR manifold. I think Dan Jones has confirmed that.
I have played extensively with the "desk top dyno" and once over .500 the lift doesn't seem to effect the hp or the torque much at all. Whether this is true on the real dyno I don't know.
If it is true then my thought would be to limit lift. A .600 lift cam is going to wear out the valve train a lot faster then a .500.
I suspect that on a Cleveland lift isn't as important as timing events.
