I had an opportunity to follow one of these on the Pasadena Freeway late one evening. Sure looked like fun. The view from behind at night is wicked. It's a Campagna T-Rex.
Photo Sharing and Video Hosting at Photobucket
T-Rex Videos
Chassis: Multi-tubular steel chassis frame.
Engine: 1164cc Inline 4 cyl., DOHC, with Ram-Air.
Transmission: Sequential 6-Speed close ratio gear box, purpose designed reverse gear, rear wheel torque damper.
Front suspension: Unequal opposed triangular arms, adjustable dampers with coil overs, sway bar.
Rear suspension: Swinging arm, dual adjustable dampers with coil overs.
Steering: Rack and pinion (2.75 turns lock-to-lock), leather steering wheel.
Brakes: Front discs: Cross-drilled discs, 11in.(280mm) diameter, 4-piston aluminum calipers.
Rear discs: Cross-drilled disc, 10in.(254mm) diameter, 2-piston aluminum caliper.
Wheels and Tires : Aluminum 16"x7" front, 17"x10" rear, 205/45/ZR16 front tires, 285/40/ZR17 rear tire.
Body: Reinforced fiberglass plastic-sandwich construction, carbon fiber windscreens and headrests.
Cockpit: Side-by-side 2-person seating, adjustable backs, adjustable foot-pedal box, 3-point retractable safety belts.
Dimensions: Wheelbase: 90in(2286mm);
Width: 78in.(1981mm);
Length: 138in.(3500mm);
Height: 42in.(1067mm);
Dry Weight: 900lbs (410kg).
Fuel Capacity: 7.5 US gal. (28L).
Performance: 0-60 mph: 4.1 sec.
Top speed: 140 mph.
Lateral acceleration: over 1 g.
Base price: ~$50K
No leaning.
To do so would require the use of motorcycle tires, which are designed for leaning in corners.
The T-Rex uses car tires. This thing is more like a sports car than a motorcycle. It has a mid-engine chassis. It corners flat, sits very low to the ground, one of the videos claim 2 G's. If you haven't already done so, take time to watch the videos.
cowboy from hell
This animal has been on the market since the mid-90's. Below are the engines used in the various years (according to Wikpedia.) A whole lot of horsepower!
GSXR-1100 Powered (1996-2000)
ZX11 Powered (2001-2002)
S&S Powered Thunder Edition T/R (2003)
ZZR1200 Powered (2003-2006)
ZX14R Powered 1400R (2007-)
The saddle bags look a bit awkward, but at least you have a place to keep multiple sets of clean underwear! Smiler
Terry
Originally posted by edmguru:
no DeTom,
I'm only 25 miles north of Charlotte.
Dang. I didn't know that. I always came into Charlote from the west side. I had a close friend who lived down there for four years andwe visited him a couple times a year. Now he lives in Nashville.
