Good Morning to All;
I recently installed the MSD Ignition module and found the same problems many of you have mentioned on this forum, to get the Tach to work I too had to install the MSD Tach Adapter 8920, I used the wiring diagram for the 1972 model and found that the LT/Blue wire was the trigger wire. The only remaining issue to be worked on now is the diode install and after researching this forum I now have the proper direction to go on.
