Hello Again,
I've installed a 6AL ignition (Duraspark dist.), Blaster coil and a 100
amp alt.(internal regulator) from Hall on my 351w. It looks like there will
be some leftover wires and I may be able to clean up the firewall by
removing the old regulator and resistor. The car is a '72 L.
If I remove this stuff can the associated wires be clipped and taped?
What wires can be removed and what should be retained after an installation
such as this?
Thanks,
Mark
