Originally posted by SwenDog:
I have a 1974 Pantera with stock guages. The tach does not work, and I'm told that an adapter is needed to receive the proper signal from the MSD module. What do I need, and how do I connect it?
SwenDog, There is a part that MSD sells for the tach hookup, they also have a good website at WWW.MSDIGNITION.COM the site has a tech number and also a tech forum. hope this helps...Pappy
You might go back through the archives of this BB. I have seen quite a bit of talk about installing the MSD setup and it sounds like just about every problem has been addressed.
