Well I really messed up last night. I started my pantera not noticing the leaking stock carb, and void of fire extinguisher. The car was in need of restoration and has been on blocks for over 20 years. I have been starting it every 4 months. well last night the spark from the distributor lit up the area around the carb. the fire then moved to the plastic tarp covering the car. The only big issue is the rear window that cracked. I hope I can find an original rear window. I must then decide if I keep or sell the car Maybe after 20+ years it is time to face it this is one project that won't get done.
