I have attempted twice to tighten the bolts connecting the tailpipe to the header pipe.
The right side is nice and the twin pipes
are straight. The left pipe is loose and hangs crooked. I am wondering if the ring
gasket might be bad? What else might cause
this problem? I can grab the pipe (when cool) and wiggle it and see it turning at the
connection to the header pipe. I would like to get this fixed as I hate seeing the exhaust pipes sitting crooked. Thanks for any suggestions.
The problem is almost always the USE of a thick 'doughnut' gasket rather than a std 3-hole sheet gasket. Due to the design of the Pantera exhaust system hanger support plus the wt of the assembly, there is considerable force directed back against the header flange. This force along with heat & road vibration eventually destroys the crushable doughnuts. But due to its thinness, a sheet gasket allows the force to go thru it without collapsing. Of course, sheet gaskets won't compensate for much mis-alignment nor grossly non-flat surfaces as well as a doughnut, so you takes your choices...My best guess.
Thanks for both your replies. This is exactly what I was thinking. So I removed
the muffler/tailpipe and found a disintegrated gasket but the flanged end of the tube is almost gone too. A little tab of about 1/2 inch is left. The rest is gone. So it looks like new mufflers will be needed. Not what I had wanted but Oh well.
The other side seems nice and tight. Should I just replace the one side? These area Hall big bore mufflers connected to big bore headers. I like the sound they make. Thanks
for your help. This board is great.
