Pull the wheel well panel, then look way up inside the body. there are 4 small nuts, in my case they were wing nuts. gently unscrew and the panels are free. I've heard that some vents had only three posts. These posts may break off. If they do, drill out the hole and JB Weld new studs in, not a big problem,
