Does anyone have or know where I can get my hands on a diagram of various reference points on the Pantera chassis? My car's MSD ignition went out which necessitated a rollback. The young fellow who tied my car down used those ratchet hold downs on my lower A arms (all 4 corners). I guess he didn't want the car to fall off however in so doing so I believe he over tightend the ratchets causing my right front tire to leave a witness mark on the inside of the fender when cornering. I know I could do it with plumb bob and string however I'm looking for something better when I put it on the bench. I have the shop manual, TSB etc. however no detailed diagram with measured reference points. Thanking everone in advance who can help.
GEORGE
Those diagrams are in the TSB #47-11-04. I have those I was hoping for more detailed reference points something from lets say the lower ball joint to a couple of set points on the car so I can triangulate and determine a more precise location. They will have to do if there is nothing else available.
Thank you.
