I have all of the original carpets, but they are in declining condition. I am trying to have them copied in the original material, but I am (once again) having a difficult time finding the correct material. I am told it is "Wilton Wool" carpet, and other than that I don't know. The upholstery shop insists it is "Mercedes Carpet", but it is not the same, the Mangusta is much thinner than the Mercedes.
While we are at it, I am also unable to find the exact front trunk "felt" (again everything is too thick), unable to find a replacement pedal pad (Fiat???) BUT GOOD NEWS! I was able to find headliner vinyl so exact I could not believe it, as well as vintage source dashpad covering. If i can help anyone with those, just ask. Thank You
Brake / clutch pedal pad - got new ones from Hall or Wilkinsons it's a Ford part( if they are out I have an extra one)
Front trunk liner, again Hall or Wilkinson have them bu they are a bit thicker, I found a closer match at a Fabric center
Best
Denis
