I want to say I paid $300 for mine and about another $125 to ship to Michigan. It came with the inserts for the tach and speedo as well as both vents, defroster inserts and the hazard switch. I needed everything, so I was very happy, even with the cost shipping. They did a nice job on the packaging, too.
At this point, all I need is a glove box, but the only one I've seen is on eBay at $300 which is a lot more than I'd like to pay.
Another interior question...
I also need a pair of arm rest, I figured since I might get a dash from Hall, I would also get their arm rest.
They made a big point that theirs were "fiberglass"! I did not see what was under the vinyl of my originals.
So is "fiberglass" appropriate for the arm rest cores? anyone use Hall's before?
as for the Hall's dash, they have to dig around to find one, so just waiting.
Hi on my 4907 (pretty much original)
..under the vinyl..is some kind of Hard foam..it is NOT fiberglas..
Hard foam is more "soft" if one would press againt it but still hard enough, but not brick hard like fiberglass.
if you go fiberglass, you would need some "softener material" below the leather or vinyl.
Matthias
If you don't mind while you are looking,
could you get a few photos all around the pull handle.
the first trimmer that recovered mine, I was not pleased with the way the "hidden" side looked, but I didn't recall what original should be. thus the reason the second trimmer now has them (i hope he still does, where ever he may be)
