Anyone else have this problem and figure out what was wrong?
I'll use the diagnosis strategy of Jack DeRyke on 02-12-2002 under the Topic "headlights" in this Forum, if I gotta do it the long way, but thought I'd ask if someone had experience that a certain connection typically gets dirty, or a Part No. from NAPA, etc., can be used to repair the switch.
Any alternatives to replacing the entire turn signal, hi/lo beam switch? My car does not have the Euro 'flash to pass' feature.
Low beams work fine in hi or low position with turn signal arm (stalk fwd or back)? Thanks.
[This message has been edited by ron norman (edited 06-26-2003).]
