I have some rust in the B-post att. to the center rocker panel. One of my options is to replace the outer rockerpanel to get to the problem. The second option is to cut out a part of the outer rockerpanel and weld it back after the problem is fixed.
I also have som rust in the back of the front wheelhouse. Replacing the outer rocker panel give me good working space and saves time (I hope. )
The rocker panels on a Pantera are, as you all know, three-piece: an inner, an outer and a center piece, all welded into a triangular assembly with a vertical center divider. As-stock, the assembly has a slight convex curvature as well.
Any recommandtion of vendors who has the (aftermarket)parts that fit the car properly?
Or is parts from DeTomaso SPA the only way to go?
