I just started my cat for the first time... It has 75 lbs of oil pressure while the starter is turning over..lol.. It PEGS the gauge ( 100 lbs ) right away... I bet it's got 150 lbs of oil pressure!.. I let it run for about six minutes, it topped out at 184 degrees with my shop fan in front of it. I'm running Brad Penn 20/50 and I was hoping the pressure would drop as the engine temp increased. I guess I will drop the pan and remove the heavy spring...
