Check your ignition timing. If that is good. Check the fuel mixture settings on the carb. Both of these, if out of adjustment, can make the engine run hot as a firecracker.
My book will make sure you get these critical things right, as said, the cost of getting them wrong can be high...
And I'd suggest to buy a Summit cooling system pressure tester, put it on, pump to 15 lbs, let sit for at least 2 hours, 80-90% of pressure should still here
Mark, my first post here. ("You are my first." Bet it's been a long time since you heard THAT !!) I saw that you suggested a phenolic space under the carb. I am working on an unmolested 19,000 mile 72 that has been in storage since 1990, and I am about to pull the carb to clean it. The stock air cleaner already touches the screen above it, so how does one address that clearance issue?
Bob Buxbaum
Kansas City, Mo.
Once that spacer is in, I don't know of any filters that are flat enough (or have a base that is sufficiently dished to basically drop down around the carb so that you can still have the engine screen). This also means that a round air filter may not allow you to close the decklid - my car came with a newer round filter that went partially under the decklid. I'm not sure if stock air filters were entirely under the engine screen, so don't slam the deck shut until you know you've got clearance.
Typical solutions:
1) Remove the screen and store it - and, if there isn't clearance for the deck lid to close, get either a smaller circumference round filter, or go for an oval filter.
2) Cut the screen to allow the filter to poke out (to allow going back to stock, you could try to track down a second screen to cut, or have a replacement fabricated with a hole, and store your original)
3) Stick with round and - I don't even want to say it - cut the deck lid so it fits (this is usually only done if you're putting in some major HP upgrades) ... e.g.
Simplest and probably most common solution is #1
Good luck!
BTW, I also think you should take a look at timing as a significant part of the equation, you may find with tweaking that and a few other items folks have mentioned, the spacer won't be needed at all.
