Don't know if anyone else has noticed this but:
I use a LOT of fuel during the day in our company which we have to account for by mileage/gals used and cost. Today, one of the trucks was running very low on fuel so I grabbed a 5 gal can to fill and bring to driver.
At the gas station I was filling the can to the 5 gal mark, when it got close to that mark I looked up to the amount/cost and was stunned to see that I had just pumped 8.72 gallons into a 5 gallon can. I still had about another gallon to go! The pump read correctly but the actual volume was almost half of what the pump display was indicating! Net result, I paid $7.02 per gallon! Complaining and showing the station manager was a waste of time. I was only getting 5 gallons, what about all the other consumers at that station getting litterly half of what they are paying for? I now long for those old time pumps that measure the fuel above the pump and then gravity feed to the tank.
We have noticed in the company a drop of about 33% in average mpg since this gas crisis started with no change really in vehicles except for the 7 catalytic converters we have had to replace due to the different chemical makup of some of the fuels....mainly ethenol additive. Mechanics at Ford and Dodge stated to us that the emmission systems were not set up for what we have gotten, they did have a tollerance window that was evidently exceded. I digress, with the fuel issue I notice that the problem seems to occur when the pumps are going slow, i.e. when slowing down for a preset sale....most credit cards and stations preset to 75.00 so the last dollar is pumping slow....probably ripping you off. From now on, if a pumps seems slow, I stop. I thought it was more than odd that I was putting 27 gallons in a 24 gallon fuel tank recently... when I had a 1/4 tank pulling into a station.
Anyway, I hope to just alert so no one else gets any more pain at the pumps than necessary.
Angelo
I don't know about in the US, but up here if you have a situation like that the Feds get called in. Sure, it will take them six years to investigate, but when they do, there will be a big fine.
I suggest you repeat that experiment with a video camera and post it to YouTube for some instant gratification. Be sure to include the big-name oil Co. logo in the frame.
FWIW, I check my vehicle mileage EVERY fill up and have not seen any change at all over the last four years in either of my daily drivers. Plus, my Pantera still gets almost 20 MPG average (yeah, mostly highway, but still pretty good for 75—80 MPH).
Temp will effect volume and weight and I am not sure exactly how the weights and measures compensate. We operate the aircraft by weight and roughly translate into gallons. Some times adding 5000lbs is 740 gallon and some time it is 760 gallon.
It will also make a difference going from summer gas to winter gas. I know my brother has to change his jets dramatically during the change over.
In Colorado there is an inspection/tax registration sticker on the face of each pump. I'd take a digital camera and photograph the empty can, the full can, the readout on the pump, the inspection sticker, and the front of the vendor's building. Then I would send the whole package to the agency listed on the pump and follow up with a call to that agency.
Our pumps are certified by the state and I think they would be very interested in such a discrepency in the vended amount vs the charged amount.
I need to fill my lawnmower can and you can bet I will check this out at my neighborhood station.
If you've been ripped off as you say...don't let them get away with it. If you confirm your suspicions with another can...call the local newspaper, TV station, and radio talkshow host. You can bet they would want to break the news and take the credit for any scandal...especially if it turns out to be state-wide.
Go get 'em!
