I am a long time PI member. I own a 1972 pre-L and am in the process of re-doing the car.
I am at the point where I am considering service to the brake system. My questions are: is the stock system adequate (assuming components are rebuildable and serviceable), or should I consider an aftermarket system.
The car is street-driven, never raced. the engine has been slightly ugraded (camshaft, Webers) but the car is driven only for pleasure and show.
What upgrades if any, would be recommended (ie: master cylinder, calipers, rotors)?
Lastly, if stock components can be reused, are there seal kits readily available?
Thanks for your time to answer these questions.
