I would also add that if you have a GTS paint scheme like mine, where the whole bottom part of the car is black and the rest is another color, and the black is painted over the other color, that it is a good idea to make sure the black goes into the door jam at the bottom and the sides up to the black part on the rest of the body (if you understand what I mean). Otherwise, if you don't have very tight shut lines, the other color will be visible in the door jam when the doors are shut! Cheers, Tim.
