OK, I helped you guys with the Webers. Now I need help with the tach.
I have a Duraspark II system in the car and can't get the tach to work correctly.
It wouldn't work at all with the one wire hook up from the distributor.
It won't work at all with the factory connection in the dash.
I have it showing me 1000 rpm whith the engine running with two a two wire hook up from both sides of the coil.
I was thinking that maybe that's the correct hook up but the polarity is wrong.
Any ideas?
