How hot does the engine bay area get??? I live in arizona and plan to paint the entire engine bay area with a bedlinner spray on paint that is used for truck bedlinners. The company says that the paint will withstand temps of 300 degrees.. I had my headers jet coated so this helps on the heat. Any clues.?? I wanted to go yellow color but they say with the heat and over a period of time the color will change to green, I have seen panteras painted but if you drop a tool or spill gas on the painted area it will ruin the area but with the spray on bedlinner paint it will not happen, Thanks
