I just now removed my worn down original pedal pads. I am trying to make more room for my size 12 feet down there. I find there is only one pair of shoes I can wear while driving. Very narrow thin soles that flex esiley........Anybody got ant tips on making more pedal footroom?
Yes,, you will be limited "where" you can drill holes. I wanted to use two bolts top and bottom on center, but the pedal arm/mouting is in the way. The top of the gas pedal is very limited too. All in all,,, it was easy. Getting down there to work on them was the hard part.
-O- and yes after I drilled the holes I painted the pedals the color of the car.
