If you remove the turkey pan from an intake manifold with the exhaust heat crossover (ala Performer) you will find yourself scratching your head wondering why your engine consumes so much oil.
HUH!!??
Is this to say the only good seal you can get between block and heads is with a turkey tray?
I guess it is just an amazing run of luck that so many other "V" design engines somehow manage to get a seal without one?
Yes, a bad head gasket seal will allow oil to get sucked into cylinders. But there is nothing special about the sealing abilities of a turkey pan gasket.
And if the oil consumption is due to it being burned off on the hot underside of the intake manifold - the only other way I can figure out what you mean by "consumes so much oil", I think the old ash on the manifold bottom is an old wives tale.
I removed my manifold last Winter, about 28K miles on the engine. No turkey tray but somehow, amazingly, no ash. None, zero, nada, zip...
Heavily milled heads will alter the mating angle of the intake to head surfaces = possible bad seal = oil sucked and burned. Cheap gasket will fail = oil sucked and burned. Failure to toss the cork or rubber end valley gaskets in favor of high quality RTV silicone = obnoxious oil leak.
It IS a personal choice, for a lot of reasons. But I.M.H.O., a perfectly good sealed, non oil-consuming engine is not dependent on using a turkey tray.
YMMV
