![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040244_zpsmo2di84z.jpg)
I found a little rot which then became bigger
![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040255_zps6rsouzkf.jpg)
![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040260_zpswggg3f7y.jpg)
![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040264_zpsuuoitlvo.jpg)
The bottoms of the tubes were rotten and the chassis rail had suffered too so I cut it out and made some plates to refit. the "Tubes I got from an Exhaust specialist who let me into their scrap Bends of exhausts until I found the correct contour these were then spli down the centre and made to fit.
These are taped then tacked into position
![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040358_zps0fqckg9a.jpg)
the rear of the cars chassis was damaged from using it as a jacking point without thought of the consequences, so I cut out the old bent metal and fitted the new plates in the pics
![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040442_zpsr14mabqm.jpg)
![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040443_zps2zwzibdm.jpg)
Rockky has made his inside curved plates like the originals, I didn't have the skills to do that and I hope mine without the holes are good enough to do the job just as well. its good to see Rockys pics, we can then learn from each other.
![](http://i275.photobucket.com/albums/jj288/pfenlon/P1040347_zpsxdx5ivsx.jpg)
I must add that I had help from Mike drew with always sound advice on what holes to drill and what holes to fill! a local sheet metal shop "Bent" the plates and tubes for me, and a pal who is a coded welder did the final proper welding, cost about $265 so far.
