Has anyone looked into the Pocono helmet requirement? They require drivers to have an SA2000 helmet. This is a full fireproof helmet. I was at the bike show on the weekend and there were a number of helmet vendors there. I found 2 selling helmets with SA2005 ratings and both were around $1800 Can. Is this a track requirement or the organizers requirement? Why wouldn't novice drivers be allowed to wear an M rated helmet? Hell, they're OK to use on a 2 wheel machine at high speeds. I think this might deter a number of people from running on the track.
Will
Special Application - SA - helmets are designed, and tested, differently than a Motorcycle - M - helmet. They are more expensive.
Main difference, as I understand it, is a car can roll, over and over sometimes, and each roll has the potential to slam that helmet into something hard. Motorcycle crash is brutal, but not normally a series of impacts.
If Pocono requires an SA, they are being very cautious, but very safe. I suggest hitting eBay and an internet search for more affordable SA helmets. The vendors, and stores, you can use for finding the size/style you want. Then go find it a good price elsewhere.
Here's a new, buy-it-now SA2005 helmet on eBay, to your door, for less than $250-
http://tinyurl.com/yohu22
PCNC Vegas track is happy with SA or M Snell rated helmets.
The SCCA has dropped its approval of the SA95 helmet, they now only allow SA2000 or SA2005 helmets, Pocono is just following common practice.
What few people understand about crash helmets is that the properties of the fiberglass shell and the styrofoam insert change over time, a helmet is considered NO LONGER SAFE at about 7 years of age. The shell and insert will no longer protect your head as designed.
I went to the Pegasus Auto Racing web site and found a "Pyrotech" brand helmet for $249, a "Bell" brand helmet for $289 and a "Simpson" brand helmet for $389. All SA2005 approved.
http://www.pegasusautoracing.com
cowboy from hell
