Will be interesting to see if this one gets off the ground. This is the car the new DeTomaso should build.
https://www.topgear.com/car-ne...-supercar-lambo-base
quote:This is the car the new DeTomaso should build.
quote:Originally posted by comp2:
It also carries some attributes of the AMX, which was designed with the Pantera as inspiration. The AMX however had fatal front end lift at speed. I don't know how this design does at speed but I would hope they test it at speed to assure the front does not lift like the AMX.
