As a new Pantera owner; where are the proper lift points to lift the car in the air? We will use either a "flat lift" under the left and right side of the chassis; or use a regular 4 point lift. Need some advice.
jacking points are just under the rocker panel on a boxed member. they are between the door front and the rear of the front wheel arch and the rear is about half way from the rear of the door and the front of the rear wheel arch. they are usually dimples which you can see or feel. hope that helps Glenn
