Good Afternoon,
Has anyone done a vacuum check on their cooling system to check for leaks?
If so, how long did it take to get the vacuum? I'm using a Maddox system to vacuum and been running for 40 minutes with no movement on the gauage. I did check the device and it is working. I know AC systems can take 30-45 minutes so I assume a 5-gallon cooling system should take longer.
Thanks,
John
#2551
