The fan light comes on and I can hear the relay clicking over when I turn the battery on and off from the switch, the fans just don't turn on. The fans are relatively new and neither turn on now which leads me to believe its something in between especially since the fuse is ok. It looks like it has the original relay, can these be replaced with a modern relay or do I need to replace these with one from a vendor? Does anyone have a modern replacement part #? I'm not the most electrically inclined, but what is an easy way to identify for sure with a volt meter whether is the relay is bad or not?
