hi,all.well we decided since the gas tank leaks causing a hazard,we'd pull the engine and fix that right away.question:do you have to pull the engine to remove the roof antena?just kidding.but this is my first mid-engine,transaxle engine removeal so thing seem a little ass backwards,things were going good until we got to the motor mounts,there frozen on so we sprayed the down with liquid wrench and let them set over nite.were going to use j.b.weld for the gas tank repair if we can.the other thing is that opening 2"x4" window at the top left of the transaxle,whats that for?will have to stuff a rag in there so nouthing gets in there,the other thing thats got me concerned is dropping ??? down into the transaxle,we are diffently going to figure that out before we start taking them apart,in our opion from getting a good look underneath,the rust damage seem to be and easy repair.one more quike question,what the best way to remove the undercoating from the engine compartment?thanks much for your help i'll have the boy take pictures today,les
