I'm a little embarrassed to ask this but I'm just afraid of doing any damage to # 1791.
Here goes:
What is the best way to remove the rear " deTomaso " and " Pantera " insignia ?
I wish to replace the Chrome with mat black insignia.
Thanks
Here goes:
Thanks
They have pins on the back that go through and come out on the other side. There are friction push nuts that slide over the pins. They can be hard to find because they are underneath the frame of the deck lid. You can feel for them, and use a small mirror. Once located, use a small screw driver and gently work the nuts off.
rrs1 posted:They have pins on the back that go through and come out on the other side. There are friction push nuts that slide over the pins. They can be hard to find because they are underneath the frame of the deck lid. You can feel for them, and use a small mirror. Once located, use a small screw driver and gently work the nuts off.
Thanks a ton for the help.
Where can I find "friction push nuts" that will fit.
The scripts do not come with them
The PO used bits of rubber tubing to secure the script
Grateful as always
Got Them
Thanks again
My plan is to respray the chrome insignia to Flat Black and reinstall them.
Any thoughts on prepping the chrome before spraying flat black
Light media blasting will help the paint adhere and enable a smoother finish. Spray painting with a rattle can is adequate after blasting but powder coating would work best. Here is a deck lid latch that was powder coated. But simply Scotchbrite and spray paint should also work.
thrillrider posted:My plan is to respray the chrome insignia to Flat Black and reinstall them.
I used SEM Black Stain Trim Spray paint about 15 years ago on All the Chrome on My Car. Looks good to this day, and is easy to touch up if needed! First I taped off everything then clean and degrease everything! Went over everything with a Scotchbrite and Clean again. Two coats of SEM Black Primer, Two coat Black Stain! I did remove the Insignias to Paint.
The reason I am doing this is because after purchasing Black Insignia the paint started to chip and peel off even with a gentle touch during installation.
So now I will apply the Black finish to the chrome insignia.
If this works out I will also spray a new set of windshield wipers I have yet to purchase.
I don't know what it is with Pantera Owners but they seem to Hate Wind Shield Wipers and Sun Visors. ( Many photos support this )
Driver's Side Visor and Passenger Side Windshield Wiper were missing when I purchased Pantera
cuvee posted:thrillrider posted:My plan is to respray the chrome insignia to Flat Black and reinstall them.
Beautiful Lusso.
I love the Halibrand Style wheels.
What dimensions do the wheels have?
P.S.
Trim looks Great.
How have you fastened your insignia.....I am having trouble getting the Push Nuts attached under the body panel..I could use a 3rd hand.
thrillrider posted:cuvee posted:thrillrider posted:My plan is to respray the chrome insignia to Flat Black and reinstall them.
Beautiful Lusso.
The Wheels are from Team 3 Wheels in San Leandro Calif. Model AC lll. With this Wheel your can get pretty much any back spacing. My Wheels are 17x8-18x11.
Just Great Looking on a Pantera and to me they scream "Cobra "
How is your insignia Fastened ?
thrillrider posted:P.S.
Trim looks Great.
If I remember right I was able to use the original fastens that came with the car. Yes they were a Pain!
Thrillrider....
If you haven't painted and installed your rear emblems yet, I have a set of black ones that I'd love to trade for a nice set of chrome ones! I'm not impressed at all with the available offerings......
Cheers!
Mangusta...
I purchased 2 sets of Black Insignia...both black flat finishes began peeling off just from normal handling much less installation and on one set the tabs didn't line up with the existing holes.
I'm sorry to report that the chrome set is scheduled for a primer coat and Matte Black finish after sanding during this down time
thrillrider
