Inside Rear View??? is attached to a 3 screw Mounting plate but you can not see
the screws Use some soapy water in a squirt bottle spray in the crack between the
mounting plate and the mirror use the old indian flat blade screwdriver trick to get the
two areas separated and the mirror should pop off from the 3 spring clips that hold it
then remove the mounting plate screws...(work screw driver slow and easy from the
back side and be ready to catch the mirror!
