Will I need new bearings and seals for this job? I have one stud that has been cut off (still able to get a nut on about 3 threads deep). I plan to replace the rear bushings at the same time.
Originally posted by LF - Teach Peace:
Oh boy, this will prove to be a big chore for one lug nut, although it most probably should be done. Do you have the proper socket/tool to index on the axel nut? These nuts torque to some amazing spec of 300-400 foot pounds! No tool = no deal :-(
I see you are in Florida. It might be worth your trouble to contact Marino at Pantera East. You could ship the uprights, since you are taking things all apart for the bushings, to Marino and let him handle this part of the job for you. He would also be able to see if your axels have started to self-destruct, check bearings, etc. You will have plenty of fun changing out the stock rubber bushings without also having to entertain yourself with the axel nut chore.
Good luck,
Originally posted by jack deryke:
Your biggest problem is, there's not enough clearance between the axle flange and the hub to drive the old stud out, and installing a new stud requires disassembly of the upright. This can be done with a special socket, but again, there are several designs of socket and some do not fit all types of halfshaft nuts. The best IMHO is the type that completely surrounds the nut AND is deep enough to accept all types of nuts. .
