OK, this may sound really dumb, but how do I remove the inside rearview mirror? I'm sure its simple, but I can't quite see it and I would rather ask than break something. Thanks for the help.
markcharltonOld enough to know better and still young enough not to care. My '71 Pantera
Not dumb at all Joe. It just pries off. No trick. It has two spring clips that press into the bracket that's screwed to the roof. Just pry gently and it will come off.
