Can anyone recommend a rebuilder for my brake calipers and master cylinder?
Hi Ian, I've struggled with the same issue and wanted to relay my experience. For the m/c I WOULD have gone to Sierra but they closed some time back So Instead I went to White Post restorations in Va and was very happy with results. I'd call to confirm they can address a stock Pantera m/c diameter if that's what you have. Mine was a non-stock 25.4mm (1.000") Benditalia unit that looks original and has exactly the same parts inside, only a few of larger dia. Had 2 similar masters done by them this year.
As for calipers I have had various sets of ATE & Girling calipers done at PMB Performance in Utah. Check out their website, they are ATE specialists and have connections with a great plating shop in their area. So they plate mounting hardware properly, too. It's been a few years now but hopefully they are as good now as they have been previously!
I've been very disappointed in mc/ sleeving work done by some other shops you would probably recognize so there could be a crap shoot element to this. Regards, Nate Stevens
Nate is right on target.
I have been using White Post Restorations in VA for multiple years for both DeTomaso as well as Ferrari brake calipers, brake master cylinders, clutch master cylinders as well as clutch slave cylinders.
Ron
They've been around a long time. They can be slow like I mentioned.
