Thank you Roland. Appreciate the help much brother.
A little over an hour later....
All done, sure helps to know what to look for.
Thanks again Roland.
Originally posted by pantera874:
No secret. Turn the drivers window down, put the door panel off. Two bolts hod the list to the quarter window. One is under the top on door weatherstrip, the other is on the lower end of the list in the door. Unbolt those and pull the list back. The you get it out.
