Well, I read in my issues of Pantera International and the POCA Newsletter about how difficult it is to get the A-Arm bushings out. So, I knew I wasn't going to try this myself. And I just happen to have a brother-in-law living 5 miles away who has been a mechanic for 26 years. He's always bragging about how he has over $275,000 in tools, including his $15,000 tool box, so I let him have a go at this project.
He whipped out his Air Hammer, and showed off his new compressor in his garage at home that stands at 5.5' tall and turned it on. He put the chisel point in the Air Hammer and cut off the 'washers' on the sides of the A-Arms. Then he got these A-Arms from the outside and started smashing the he** out of the bushings from all different angles. Several came out fairly easily compared to the other bushings, like in under 4 minutes. He used a C-clamp looking device that is used for removing Ball-Joints (which had some short round sections of pipe in the kit) and pushed some of these things out where he could using an air ratchet or whatever those air wrenches they are called.
I'll tell you what. These things were a real tough project to get accomplished. He got all 16 bushins out in 1 hour and 30 minutes. Told me they do this at work all the time, but they normally don't have 16 bushings. He said his hands and arms were really tired after that. No kidding, Mike!
This stuff scared me a little bit. I could see that there was no turning back, but this guy does this for a living for almost as long as Panteras have been around.
Well, when it was all over and done, there was one groove in one of the A-Arm holes where the new polygraphite bushings were going to go in and the edges where the 'washers' were, were a little rough, so I took them home and got out the drill with the grinding wheel attached to the end of it and set to cleaning up the burrs and rough edges. Took about 45 minutes and I was sweating alot more than he did, after what he did!
So, there's more than one way to skin a cat! And when I asked him, 'hey, isn't there another way to do this?' He said, "yeah, of course. You can take them down to NAPA or another machine shop and 'vat them' in a solution which cleans all the paint and rubber off of everything and then heat them up to 300 degrees fairenheight, and they will just slide right out. But this is faster, and that's how we do them, Ron, 'because time is money, and I get things DONE!"
Wow! But it got done. This guy does hard work! He's good at it and makes $90,000 a year as a Master Mechanic, and earns every dime of it. Way to go, Mike. 'You ARE a Hot Shot Mechanic, Mike' I told him. He liked hearing that alot and more people should tell him that. WOW!
I wouldn't ever try this myself. I have no idea what it costs everyone else to do this, but I OWE him for that. Thanks Mike, da** proud to have you as a brother-in-law. He has my respect!
[This message has been edited by ron norman (edited 07-10-2003).]
