joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
The 'aero' caps that Marlin is using must be a bigger size, the one I have fit exactly in the existing gill cap hole, which did require adding a backing plate for it to bolt to, but a relatively easy job, no milling.
I have two different DeTomaso supplement catalogues for Gr- 3 and Gr-4 cars, but curiously, neither lists the race-popular two- piece fuel cells (one on each side of the engine). During the time when Panteras were being raced in international events, homolologation rules may have required a stock tank. The two such cells I've seen were from the '80s.
For short-duration events, some Panteras used an 11 gallon tank mounted in the front trunk. D. Quella's plastic Pantera has this type of fuel cell. Sinking a well down where we usually drop the battery, you should be able to get another gallon up front and avoid the cross-connection tube running between two rear tanks.
And finally, for those who just can't bring themselves to saw up a good 'gill', I have a silicone rubber mold of a right gill. I used it to fabricate a gill from fiberglas, then saw that up to make my right-side radiator access door, duplicating a stock left side fuel door. You could do that, too.
I seem to recall reading about an extended range/auxiliary tank as being an option on cars being sold on the European market. But, that was over thirty years ago when I was reading everything I could get my hands on about the car. I wonder if it's in the parts book.
