Lloyd,
For saftey wiring the ring & diff. bolts and changing all bearings,I removed the ring gear and diff. assy. from the case by removing the diff. cover and removing the ring/diff. housing and the diff. cover as two pcs.Is it ok to install the new bearings on each pc. and re-install the two sections in the same way? Any other recommendations, precautions will be appreciated.
