WHEN I GOT INTO MY CAR THIS PAST WEEK-END I NOTICED THAT THE HEAD-LINER HAS COME LOOSE AND IS SAGGING. IT SEEMS TO BE LOOSE ALL THE WAY AROUND AS IF IT WOULD FALL OUT IF I REMOVED THE RETAINING MOLDINGS ON THE SIDES.
IS THIS EASILY OWNER REPAIRED? IF SO WHAT IS THE PROCEDURE? OR SHOULD I SEND IT TO THE
AUTO UPHOLSTERY SHOP? I WOULD RATHER FIX MYSELF IF POSSIBLE. THANK YOU. JOHN
SVNT4PANTERA@AOL.COM
