Chuck TX , Team!
Thermostat is RT 310,
Fluydine cooler all according George P recom.
- smaller water pump pully for more ref..
- Edelbrock high volum water pump
- heating pipes stubbbed
- Fans are running, correctly
- Radiator swicht need to find the data, but per George's advise to balance between Thermostat and On/off radiator switch
- NO air in system..got bleeded again and again..(Tx Jack's hint), stable now..1 bouble max at radiator
- is still the old modle set up with overflow tank..correct lits applied
As I now measure RIGHT at the hotest spot was wondering for REFERENCE..Temp readings.
(the cat was running at 180 km/hour for a while ok..think 3800 rpm..), (will next use my temp hand held device to confirme..the Italien gauge precision readings)
