I'm doing the modification to my shifter where I've pulled out the snap ring, removed the cap that holds in the spring and removed the spring. Does the cup the the spring sits in need to be removed also in order to complete the modification. I've tried to remove the spring cup but it won't come out. It doesn't appear to be held in by a ridge but something inside. It moves up and down but won't come out. Should I just leave it there? I've read some of the previous posts from guys who have done this mod and one suggests filling the hole with grease and then putting a quarter over the hole. Any one think that's a good idea? Thanks Vince 6909
