My new wheels have this lip in them. These require shouldered nuts, don't they? The vendor sent me regular tapered nuts. I was told this is unsafe to use the tapered nuts on this type of rim.
Will
quote:These require shouldered nuts, don't they
quote:The vendor sent me regular tapered nuts
quote:You should NOT use any washers if the nut and wheel are both tapered
quote:What thread pitch should I be searching for?
quote:Larry is going to post a pic of the ones I'm going with.
quote:Originally posted by LF - TP 2511:
...there is still the issue of why is there a recess that looks correct for a mag type nut's washer?
