Please let me know if you have one of these that is gathering dust. Mine is cracked. You can see the horizontal crack just below the brake light switch. The switch was difficult to get out and the crack likely occurred when the switch was over tightened. Thank you.
Are you sure its a crack?? Is it leaking brake fluid? It doesnt looks as a crack to me.Its bras...looks to be a light scrats or dent.
The crack continues all the way around to the other side. I'm not sure that it leaks but it likely will. Brake systems have more than 1000 PSI pressure.
If you get no response, most of the parts vendors have take offs, as that part causes problems in many cars. Call around-
I still need one of these. Please let me know if you have one that is available.
i have one from my 71. i believe it is steel though. havent seen it for years. my take a while to find.
My cracked assembly is from a 71. If you can find it, yours should work in my car.
I'm still looking for one of these ...
Steve, I talked to my neighbor Larry Stock in Carson City, NV last week. He has several working valves on the shelf. 1-775-722-7755 cell
Steve, did you ever get one of these shuttle valves? I have three coming to me if you need one. Did you ever rebuild one? If you did, can you tell me how you got the cylinder and the sleeve to go back inside??? I am stuck at that step.
Yes, I did get a valve. I got my rebuild kit from Wilkinson and it worked correctly. I have rebuilt valves for three Panteras with the kit he supplies.
Also, the rebuild is easy once you get the piston out. Take pictures. On one of the valves I had to use grease to pump the piston out.
