While replacing my clutch and slave cylinder I discovered that an adjustment tab is missing/broken off of the mounting bracket. Does anyone have one that is available that is only gathering dust on a shelf?
I'd find a local welder and have him fix your OEM bracket. Virtually any used ones will cost as much as the welder charges to buy, clean up, sandblast, and paint to match the rest of your beautiful car. My 2 cents-
