1306 is coming together slowly. Today I was sick so decided to post some pictures. The plan is to have the car back together before Vegas. My goal is to get all the heavy expensive mechanical done. The smaller items will be taken care of as money permits like interior, painting under the hood & decklid, and polished nuts & bolts
Images (9)
  • 1306_Racer_005
  • 1306_Racer_002
  • 1306_Racer_004
  • 1306_Racer_006
  • 1306lf
  • 1306rear
  • 1306engine
  • ebaysell_047
  • 1306_006
Originally posted by 74 GTS:
Nice work! Kodiak Wheels? What size and which tires are you running?
Keep us in the loop.
Mitch
Yes part of the group buy I went with 17"x9" front (hope they fit) and 18"x11" on rear
The tires are Michelin Pilot Sport Cup tires made for autocrossing or track but are DOT legal and will probably work OK on the street unlike racing tires. However they will of course wear quickly being softer compound.
Car needs lots of TLC been sitting since 1984 before I purchased it. I should have plenty to post in the next couple weeks as this thing comes together.
Spent today installing Hall front upper & lower chassis braces and the brake lines. I also trial fitted the new power brake booster and master cyclinder it was a bit of a tight fit.
Originally posted by 4NFORD:
How's about some shots of the whole car?
Added some pictures of the whole car just a little warning if you see this car in Vegas the paint is not even close to show quality and there is a few dings and scratches. As you can see in the pictures I really haven't had the car 100% together yet. I did get to drive her with the stock motor and trans before I removed.
Currently trying to get the front suspension back together so I can get the car rolling again. After that back to plumbing & wiring engine.
Car looks great! Its coming together well! Do you still have the Hall wheels? See you in Vegas!!!
