Couple of recent 'small' probs, good solutions.
1. Sorry excuse for a radio. It was the original, with reciept and all. Sounded like it was about 30 years past its best days.
2. Too much interior noise to compete anyway.
3. Horns wouldn't get the attention of paranoid deer.
I took my car to the stereo place to replace the speakers (but using original holes, "Muntz" grills, etc) and 'new' vertical radio.
The guys mentioned how much they could reduce the 'tinny' sound of the door shut (hardly noticed before) with DynaMat. I've put the heat/sound foam all in the floor and firewall which helped hugely, but after I rapped on a door 'with' and 'without' Dynamat I was sold.
My sagging headliner was sending orange dust from the foam throughout the interior daily, so had them remove and DynaMat my roof, new foam, reinstall headliner.
They put it on the inner door skin AND on the inner door panel, so two layers separated by dead air. New Boston Acoustic speakers, repainted my Muntz grills (they thought I was nuts.) Put in a vertical dial Mitsubishi, which is WAY better sounding and fine for me, but still marginal for a stereo nut.
Odd as this sounds though, the font on the radio is a near dead match for the gauges, and in black it 'looks' right.
The doors shut like a safe. Unreal. They just 'thunk' dead in their spot and there is NO residual noise or echo. You tap on the roof and nothing, the sound just thuds to nothing.
I pulled the firewall and attached a full layer of DynaMat to the inside of the fiberglass (now atop two layers of the metallic heat/sound shield which was already on the firewall side). Plus I had to tighten my belts anyway, so made the best of it.
The car rides WAY QUIETER, but if I drop the window, that exhaust note is still right with me. The car just feels like, well, higher quality.
I then pulled my little anemic low/high horns tonight, cleaned 'em, painted them, put a NAPA 'high' tone (made by FIAMM) with my original 'high'. The things are in perfect harmony, one octave apart, very European 'pitched' and several times louder.
So, I've got less sound where I need quiet, more sound where I NEED noise, and good tunes to go with it. A good weekend.
These cars are great.
